Originally Posted by destroyer125
Blasting cabinets are cheap....Buy the $200 one from HF and you will be alot happier in the long run.
Originally Posted by acidrain
I started with that exact unit... added a light and it work good for a couple of parts at a time.
Here is a hint... replace the screen with a plastic one to avoid scratched parts when you lay them down. I saw some punched plastic sheet at Lowes the other day.
I would love to follow in your footsteps... but I wonder if spending more now would help...
Ok now with the unit between 2 or three choices (also looking at TP model
http://www.tptools.com/p/427,54_770-...g-Cabinet.html)
What should I use to power the unit...I dont want overkill but I would rather not start with something mediocre and then have to upgrade (such as my powersupply ordeal)
