Re: Sanding Tips, Tricks & Secrets
Try doing a Dellorto for mutipule tight area's.
I just use a piece of wire rounded off and start with a 120 grit wet & dry and then move up the grits then little felt wheels and compound. Yes its time consumming but you get a great result
