Re: Copy Cad crystal life
Should be fine,
Add distilled water to correct level and heat to operating temperature. turn on agitation and leave for several hours. stirr occasionally with a clean plastic or wooden stick. once everything is disolved, filter through cloth filter into clean buckets. Then filter back into tank.
I would plate a couple of corrogated steel sheets (small) or even a couple of flat sheets just to re-season (my term) the solution.
cheers... Mark
