Originally Posted by LU_aDaK
What do you use to plug the internal areas as to not blast them ?....
A pencil sharpener and some dowel works great. Sometimes I use SS bolts. For the breech, use large rubber stoppers. For bodies with slots, use a piece of rubber hose for the inside (cut to fit), and cork both ends.
Originally Posted by mkriegs
So you're saying that you just fill it up as much as you want and you don't get problems?
I fill mine all the way to the screen... problem solved!
