Originally Posted by baz
yes i use that grease too (well the one i m using looks more like a hard wax), but when i m done with the 320 with the grease i go over the area with polishing compound on top of the used 320 roll takes 2 minutes and it makes a little easier to buff after.
Not a bad idea...you're gonna give away all your secrets if you stick aroud here long enough!
