  #15 (permalink)
Old 04-11-2008, 06:12 AM
mpierich mpierich is offline
Default Re: Sanding Tips, Tricks & Secrets
Originally Posted by quadracer2cool4u View Post
mpierich, can you post the link of the grease that you are talking about. Witch type do you recomend?
Thanks!!!
Look here: http://www.caswellplating.com/buffs/compound2.html
Use the F-10 for high-speed stuff like cartridge rolls; use the F-26 for slower sanding belts, etc. DO NOT use the F-10 for slow speeds...it'll put a glaze on the abrasive that ruins it and is tough to get off even with a belt cleaner.
