Originally Posted by IAMaxxer
Just wondering if any one has come up with a fool poof idea.... I have a job needing to do 100 screws and of course looking for the easiest way out....
Wrap 1/16" aluminum or titanium wire around a rod (I use 3/8" rod) and make a spring. Make sure you leave enough unwound wire to make a hook to hang in the bath. Stretch the coil out enough that you can push screws into the spring like area of the coil. This will give an amazing connection and easy accessability when you go to wash them off. 100 Screws will probably need a couple coils.
