Old 04-15-2008, 07:53 AM
Harleydad's Avatar
Harleydad Harleydad is offline
Default Re: Two tone rim help
Originally Posted by peter61 View Post
I'm getting ready to do some chrome Dodge ram rims,the customer wants ram red and extreme chrome.Ram red on the recessed areas and extreme chrome on the other areas,any advice on powdering over the chrome?
Clean clean and clean them again. Since these are solid colors your using, you can go over the chrome with a scotchbrite or lightly blast to help with adhesion. I would out gas those at 450 degrees for an hour to see if the chrome will hold up. If it bubbles/blisters it should be stripped. I would spray the chrome first and fully cure it. Do the red next 1/2 - 3/4 cure and then shoot the whole rim with clear and fully cure according to the cure instructions for the clear. If you spray the chrome over the red, theres a good chance it will bleed thru.
