Old 04-17-2008, 11:42 AM
benherr benherr is offline
benherr is on a distinguished road
Default Re: How to clean the PC gun???
Originally Posted by Harleydad View Post
Too slow or too quick of a heat up rate can contribute to OP. If I have some heavy material I'll put it in a 450 degree pre heated oven and monitor the part temp until it gets close (350 degrees) to cure temp (400 degrees) then turn down the oven to cure temp.
The opposite with thin walled material. I'll turn the oven on and set it to cure temp (400) and put the part in when the oven reaches 325 - 350.
In both scenarios, start the clock when the part reaches cure temp.
Does that make any sense.
harleydad,
absolutely it makes sense to me. I've been placing the piece in the oven and turning on the heat and waiting for the piece to reach temp and then starting the clock. No wonder I've been getting OP. Most of the items I'm PC are between 3/8th to 1/2 inch in thickness (T-6061 aluminum).
Thanks, I may just get one done that doesn't look like an orange and carters like the moon.
Ben
