hey John PLC, I think you misread my post. I said the white wire is usually hot on a 230v circuit, I am talking about a normal circuit like ou would use on say a 230v air compressor. The black and white connect to the circuit breaker, double pole connections, then the ground would go to the ground bar. Anyways, he took the time to trace the wires himself, as I suggested, that is the onl way to do it. Don't assume everything is ok with electricity cause that is how you get hurt. Alwys assume the electrician who wired up your house is a total moron that was boozing it up all day before he came to take you money. Lesson for everyone! lol
