Re: Buffer Vibrates with new wheels
The hole fits tight on the shaft and the nuts are tight against the aluminum arbors.
I think the hole is off center by a little bit on each buff. (I have 5 buffs stacked up on each side.) These are 12" buffs so if they are just a little off they shake a lot. It seems worse on the loose sew side than the spiral sewn side.
-Joe
