Old 04-25-2008, 06:27 AM
mpierich mpierich is offline
Default Re: Buffer Vibrates with new wheels
Originally Posted by jfedullo View Post
Actually, maybe the buffs don't fit tight on the shaft...
The shaft measures 1.250" with my caliper and I ordered 1.25" holes so they are nominally the correct size, but I just loosened the nuts and checked and there is a little play. There is much more play on the loose sewn side than the spiral side. The spiral fits pretty close, but not really "tight" The loose sewn fits loose....
I'll post pictures tomorrow when my wife gets home with the camera.
I think you are on to something baz. Maybe if I try to hold the buffs centered while I tighten the nuts I will have better luck. Sounds like a project for tomorrow.
-Joe
Maybe some thinwall tubing as a spacer would help center them. I've also used tape wrapped around the shaft as a spacer. I generally just eyeball it myself, but then I usually don't stack wheels.
