Curing... slowly, very slowly
I have the Caswell "Pro" kit with a 1500 watt lamp for curing. I'm coating suspension parts and the lamp doesn't work very well melting the powder. I end up putting the lamp very close to the part and then moving it around, which takes forever. The max temp I've been able to record was about 220 degrees. Is there any solution other than adding lamps? Is it possible mine is defective?
