Originally Posted by Travst
I have the Caswell "Pro" kit with a 1500 watt lamp for curing. I'm coating suspension parts and the lamp doesn't work very well melting the powder. I end up putting the lamp very close to the part and then moving it around, which takes forever. The max temp I've been able to record was about 220 degrees. Is there any solution other than adding lamps? Is it possible mine is defective?
If all you can get is 220 your powder is way under cured and will not last.....
