Old 04-29-2008, 09:17 AM
woody103 woody103 is offline
woody103 is on a distinguished road
Default Re: Oven or reflector with infrared
A 1500 watt heat lamp is not enough. I have 2 2000 watt heat lamps and still have problems. I tryed the building a box thing with both heat lamps and it did not work that well. Took a long time, and alot of electric to get up to temp, and then still was not good heat.
If you are building a box or enclosure for heat lamps, you might as well go and build the oven for not much more.
JMO.......
Woody's Refinishing
Abrasive Blasting & Powdercoating
dwoodworth103@aol.com
