Old 05-01-2008, 03:57 PM
97Dually 97Dually is offline
97Dually is on a distinguished road
Default Re: Which air compressor filter/dryer?
It is alot of pvc, but the farther you run that air, the cooler it`ll get, therefore more water drops out. I only have a 6hp 60 gal compressor and thats about what it took to work. I started out with only 80ft and still had some water in my lines at the drops. PVC is cheap, I think I only have about $100 in all that line and the needed fittings. One other thing, if you`re gonna use pvc to plumb your shop, put a drip leg before each drop, it will help.
