Old 05-01-2008, 04:30 PM
glennpd glennpd is offline
glennpd
Default Re: Oven or reflector with infrared
I have been toying with the idea of two galvinized garbage cans. One 50gal and one 30gal. Set the 30 inside the 50 suspended with some firebrick. line the airspce between the cans with oven insulation (J. E. S. industries) Use the two heat gun method through hole cutr through both cans, us a remote oven thermometer. use a hanging wire run through the inner (30gal) lid to suspend the item. Line the inner (30gal ) can with HD aluminum foil. Seems like this should work for a lot of parts.
