Old 05-02-2008, 10:23 AM
Travst Travst is offline
Travst is on a distinguished road
Default Re: Oven or reflector with infrared
I bought an old oven last night for $25, so I'm moving forward. The next step is wiring the garage for another 220v circuit. Unfortunately, the breaker box in the basement is full. On the plus side, the main breaker is attached to my garage. I'm going to consult with my mentor Freddy to figure out the best way to wire up my double oven setup I described above.
I'm wondering if I actually need two 220v outlets if I stack two ovens. As I plan to remove the top of one and the bottom of the other to stack them, I'm considering leaving the top element in the top oven (broil) and wiring them into the same temp switch... in other words, using only one of the oven control units or even substituting a PID. Wouldn't one 220v outlet work to support two elements? I'm going to look at the various calculators to try to figure it out.
