Old 05-04-2008, 06:44 PM
junkorgem junkorgem is offline
junkorgem is on a distinguished road
Default Re: Flex Shaft Parts
Thank you for your reply, I have used many of your previous posts as I have been polishing different parts on my bike. Anyhow, all of the bearings in the end of the shaft were in the vibrator assembly, so I do have to have a shaft made with the correct OD to fit the bearings. But.. the other end of the shaft needs a collet/drill chuck or some way to attach a buffing wheel. I think it may be to difficult to reduce the length because it has ends crimped on similiar to a hydraulic hose. I found a used shaft on ebay, I will try that one first. Thank again, Greg
