Re: paint to protect against anodizing fumes
IIRC, there's a diagram in the manual of a fan setup that is out of the air flow of vapors. I can't remember if it's an air jet or fan but either will work. The principle uses air injected into the exhaust piping causing a vacuum to occur at the other end. This draws the fumes into the pipe and expells them.
I have your setup but have been planning to make the change over to the air vent. In the mean time, an epoxy paint should do the trick.
