Old 05-05-2008, 12:12 AM
KCV6's Avatar
KCV6 KCV6 is offline
Moderator
Default Re: best method for heating Zincate solution
Just finished 10 pieces (starter motor end caps, thermostat housings, oil filter adaptors etc). worked MOSTLY fine. These were severely coroded so I ended out with minor blistering on 2 pieces after much copper building, sanding, building, sanding, buil......... where the pits were quite deep. Not enough prep on my part. I'm going to re-work the pitted areas and try a quick re-zincate and see how it goes. Other than that the zincate worked fine.
Cheers
Mark
