Re: As frustration sets in...
The booster will fit in the bottom of a 3.5 gal pail with .5 to .75 inches of clearance. I used two 4x8 anodes doing one side at a time.
Do I rub off the white rust dry?
Right now I can't go from blasting to plating.Blast at work , plate at home.
Will the acid solution you mentioned be correct to strip the zinc and chromate finish?
I think my prep work needs some work.Seems like I always have to run my solution through coffee filters.I will get some new crystals and have been thinking of a new container also.
Thanks for taking the time to reply.....
P.S.Glanced at your link,will read when time permits.
