Old 05-08-2008, 09:57 AM
seanc seanc is offline
Zinc Plating Guru
Default Re: Copy Cad Zinc Blackener
I don't use the blackener on anything but pure plated parts, so this may not eb entirely applicable, but ...
I'm having difficulty achieving a black finish on a zinc workpiece.
What is your "zinc workpiece"? pure zinc or a die-cast alloy? The blackener needs a high percentage of zinc content.
It was previously phosphated, and I have stripped it back to the metal using Birchwood Casey Blue and Rust Remover (Sulphuric and Phosphoric acid based), and steel wool.
I'm not familiar w/the Birchwood products, but if it's got phosphoric acid, you may be re-phosphating the part, preventing the blackener from reacting with the zinc.
Why not use just 5% sulphuric as recommended in the manual?
Can anyone recommend a better way of pre-treating the metal to get a better finish please?
I think you need to better identify the metal alloy. If it doesn't have high zinc content, it just won't work as expected.
Sean
Seans Zinc Plating page
