well my bench grinder is giving out on me and Im planing on buying a good buffer.......would like to pick up a hanging shaft driven polisher/grinder for the hard to reach stuff......dont want to spend a ton but I found this
INCLUDES VARIABLE SPEED FOOT CONTROL
Tackle detail work in wood, metal, and plastics. This heavy duty tool grinds, deburrs drills, polishes, buffs and sands. Motor hanger lets you mount it on any vertical surface. Ball bearing motor. Includes: 1/4 HP motor, 38'' flexible shaft, handpiece, 4 MM (5/32'') key-type chuck, variable speed foot control for hands-free operation. Double insulated. UL listed.
Motor: 1/4 HP, 1 phase, 60 Hz, 115V
Speed: 15,000 RPM
Shipping weight: 5-3/4 lbs
would this work with say 4inch wheels
mabye a 6"
also I have a question about the parts Ive done...... I have a couple wheels that have something in them that causes scratches.....have raked them and still theres something in them....Can I wash these in something and how do I dry them so they dont mat down.....also do you clean each part with a wax and grease remover before the next step.....Ive tried both and it seems to work out better without cleaning between.......but I'm getting mixed compounds on the buffs....your thoughts
