Old 05-12-2008, 06:22 AM
mpierich mpierich is offline
Default Re: looking to expand my polishing tools??????
Originally Posted by 89notchback View Post
Thanks I guess Ill grab a better drill and try it with a drill.....I need something a little bit more mobile than the bench buffer
Baz is right again, that shaft will twist up on you with a 4" wheel on it, but it would be good for detailing. An industrial strength shaft like Caswell sells is great on a 1/3 hp motor.
A lot of use like this tends to burn up electric drills, especially light ones that I'd want to use for very long. If you have a decent compressor, an air drill is lighter and will last a lot longer.
