Old 05-12-2008, 09:11 AM
Harleydad's Avatar
Harleydad Harleydad is offline
Default Re: ? on using top coat colors
Originally Posted by benherr View Post
OK, just got my lolli blue and red, but not sure exactly how to use them. I've been reading but still confused. do I need to have some type of base coat color first and then apply the top coat? I'm PC polished aluminum T-6061.
Thanks for the help in advance.
Ben
The need for a base coat depends on what you're coating. Trans/Candy colors look best over chrome or a polished surface. Other surfaces such as steel, cast iron, blasted surfaces, etc..........a base coat of something along the lines of x-treme chrome or a silver are in order. You should be fine over that polished aluminum, just to sure to clean real well to remove all polishing compounds.
