Re: Need element connectors
You may have to run your #6 wire to a terminal strip outside of the oven wall and then size a wire to the element wattage to bridge the distance from the terminal strip to the element. You should be able to purchase hi-temp conectors to make up the element end of this jumper wire. Do you need spade lug or the slip fit type connectors ? Fred
