Originally Posted by lcaswell
The test for die cast is a two part process:
1. Put a magnet to it. If it sticks, it's not die cast or aluminum.
2. Have some water handy. Take a drop of battery acid and drop it on the part in an inconspicuous area. If it bubbles, it's pot metal (die cast). If it doesn't, it's aluminum. Drench with water to stop the acid attacking the metal further.
To get an antiqued look, you can replate die cast with our Flash Copper Kit, then use one of our antiquing solutions on the copper plate. You can also brass or bronze plate it, after copper plating.
See Plating Kits Chrome Plating Kits Aluminum Anodizing Kits Electroplating Kits - Caswell Inc.
Thank you.
It is not magnetic but I still haven't checked for acid.
I have a further question about the antiquing solution. Will that cause all of the brass plating to darken evenly? Because it looks like the low spots where the lettering is embossed in the plate are supposed to be much blacker than the rest.
