Old 05-15-2008, 12:38 PM
Grumple Grumple is offline
Grumple is on a distinguished road
Default Re: Anodize or Powder Coat?
Glad I asked. Thanks. Being I am still getting set up etc I was wondering if you can remove powder coat after it is sprayed on, to clean up an area or is it better to wait until after you oven cure it? On the hub spoke holes for instance, if you plug them I think it would be hard to find a plug (maybe I am wrong) that would fit properly where the end of the spoke is recessed. Is is proper procedure to use a drill bit after powder coating to clean up this area or is it ok to remove the sprayed powder before curing it? What is the correct way?
Grumple
