Thread: Blown PID?
Old 05-15-2008, 08:33 PM
jasonandres jasonandres is offline
jasonandres
Default Re: Blown PID?
I checked the temp with an infrared gun, it's about 4 degrees higher than what the PID says. I ran the auto function, it still pulses, I can hear the elements going on and off with the pulse. If I have the target temp around let's say 100 degrees above what the oven actually is then it will pulse for about a minute then stay on steady, but if it's lower then around that 100 degree difference then it pulses. Also, the PID overshoots the target temp by about 15 degrees and begins pulsing again. I checked the other parameters and they seem OK, and the TC is wired directly into the PID. Man this is confusing, does anyone have a clue what's wrong?
Thanks
