  #10 (permalink)
Old 05-21-2008, 04:48 PM
Grumple Grumple is offline
Grumple is on a distinguished road
Default Re: Does PC power supply work?
How does the btu's figure in to the water temp? Like in the example above with 922 btu's in a 2 hour run, how many degrees does it raise the water temp? A BTU is the amount of heat required to raise the temperature of one pound of water by one degree Fahrenheit so if he has 20 gallons at 8lbs per gallon thats 160 lbs....So would it be like 6 degrees??
Grumple
