Re: wax
The heating is fairly important, but you may get away with just filtering. How do you heat your copy chrome normally, or do you just run it ambient?
Don't add the full bottle, always plate a test piece and then only add enough brightener to suit your plating needs. 10ml will plate about 5 amps for an hour.
I have considered clear coating parts, but have not tried it yet.
Cheers
Mark
