Re: Zinc plating issues
Thanks Mark. Yeah I keep forgeting the CC thing. Some meters have a procedure you have to go through others are auto setting. I believe mine is auto setting so you set the voltage first then hook everything up and set your current. My voltage is already set to 10v and whenver I turn up the amp knob I get nothing. Fluctuates around .06amp but won't dump. I'm unsure if it's the plating tank makeup or if it's wiring.
Ken-
