Thread: Alum prep
Old 11-01-2003, 09:20 AM
dsacco1013 dsacco1013 is offline
dsacco1013
Default Alum prep
I am going to place the "big" order today, an was thinking I need this...Iron Phosphate Primer I am going to order yellow in the Weatherable Coating it is TGIC powder.
I plan to coat intake, valve covers, heater block off plate, and transmission housing(while it is apart). Also will the heat from the 1500 watt IR light be not so good for the seals in a water pump?
Thank you in Advanced
Dave
