Woronko plating tank
I just got my CopyChrome kit and have been playing around with it. So far the results have been good. I need to plate some 1-1/2" square tubing 33" long in the woronko tank I built just fo that purpose. Can I start with the tube completely submerged in the solution and raise it after each section has been plated? I know the manual says do it the opposite way. How would you calculate the amps needed using a 4"x6" anode on each side? How far down the tube would the nickel plate with this size anode?
