Re: Green olive drab ph will not rise?? why??
Your pH should be 1.8 - 3.3. The optimum pH is between 2.0 and 2.7 and is maintained by adding equal increments of Part A and Part B to the solution. . Do not mix Part A with Part B when replenishing solutions. Part A contains chromium compounds and is an acidic solution. Part B is an acidic solution.
