Using a reverse osmosis unit in the system
Is it better to have water running from a reverse osmosis unit through the cleaning tank continually or to completely replace the water in the tank every so often - or perhaps a combination of both? How would you connect up the reverse osmosis unit? - with the pipe to the bottom of the tank and a overspill outlet at the top??
Any help much apprec.
