Old 07-03-2008, 04:08 PM
x1rider x1rider is offline
x1rider is on a distinguished road
Default Finally finished my PC curing oven!!! ...and one question
I finally finished my powdercoating curing oven I've been working on for a while now. It's big enough that I will be able to PC wheels two at a time.
The heat source is a 45000 BTU propane infrared heater.
I wanted to be able to take the whole thing apart because it's too big to keep in the garage all the time so I had to weld bolts to the frame and nuts to metal straps in order to rig up a quick mounting system (that's why it took so long, plus I was making my plan as I went).
At the top, there is a grille where the parts will be hanging from, I'll put a winch on my garage ceiling to raise the grille/parts in and out of the oven.
Pic of the whole thing together.
Now I just have to try it see if it works, I friggin' hope so with the amount of time I spent on this project!!!
One quick question, I want to PC a valve cover flat black, do I need to use a high temperature powder for a valve cover or would a regular powder do?
Thanks in advance for any information.
