Originally Posted by welterracer
I did a valve cover for a eagle talon, and the header came up and then down and was very close to the valve cover..
It did discolor the valve cover..
Your application looks like it wouldnt require the high temp thou
I agree. It just depends on how hot the header or turbo will get beside the valve cover. If it reaches over 450F or so...you might have some issues.
Use your judgment on your setup. Personally I think you will be ok with regular powder. Worst case just test it and see how it holds up. It is YOUR setup anyways and you can always strip and re shoot.
