Re: Size of tanks
Matt,
It won't do it in the 6 gal setup with a round tank. But there is light at the end of the tunnel. All you need to do is find a suitable PE or PP container that it will fit in that is say longer and thinner so you can have a second tank for longer bits. You will want to put extra anodes in to up the anodes surface area so you get a nice even plate. I believe they touch on this in the manual. The spare set of anodes is a good investment and is not wated anyway.
Cheers
Mark
