  #8 (permalink)
Old 07-16-2008, 04:00 PM
FigureLLC's Avatar
FigureLLC FigureLLC is offline
Caswell Platinum Member
Default Re: help setting up the blast cabinet
Originally Posted by FigureLLC View Post
good point about the dust collector. i don't know if ours will handle it, as-is, but i can sort that out a bit later.
ok, it's a bit later, and after maybe 30 minutes of blasting, i guess the aluminum oxide chewed up the shop vac motor. on the bright side, the blaster works well. that tp tools high volume gun is sweet. thanks for the recommendation!
Len
Figure Engineering, LLC
