Originally Posted by FigureLLC
ok, it's a bit later, and after maybe 30 minutes of blasting, i guess the aluminum oxide chewed up the shop vac motor.  on the bright side, the blaster works well. that tp tools high volume gun is sweet. thanks for the recommendation!
tptools sells a 1 hp dust collector I used for mine.
Also I used a bad boy pressure pot blaster with AO @60-100psi depending on metal or aluminum. My compressor was a 120gal with a 3.5 hp motor. Yes it was under powered, but it worked. I would say a 5hp (true 5 hp look at amps) and a big tank will be fine.
