Welcome fellow 911 restorer!!
Hi Mark,
I have had really good luck with my yellow cromate plating from Caswell.
I use a bead blaster to remove rust and scale on smaller parts like your pedal cluster then powder coat them!
For nuts and bolts, I have been using the six gallon copy cad kit and dipping the parts in yellow chromate just after a quick rinse. They are doing well.
The problem that I am having is the larger plating that comes out gray, like my postings above.
Tom
