I would not recommend you connect the RO unit to your tank. The concept of these systems is simply to produce 'pure' water.
So, you'll make your pure water in a seperate container, THEN add it to your plating tank.
The RO unit makes 10 gals per day, so its pretty slow, but then 70 gals per week should keep any Caswell Plating kit more than happy.
