I don't know if you all keyed into the fact that there are different types of "wash" treatments as far as bond goes on this site, but I'll give you the inside skinny before Caswell cross-lists these puppies.
We all know that a phosphating solution to your steel available in the powder coating section. But what do you do for that home-run grip on aluminum or copper/brass?
For aluminum, ALCHROM880 is a great choice to use. Same pretreatment, but best suited for non-ferrous white metal such as aluminum. It's even mil-spec approved! ( approved by the U.S. Government as a viable treatment). For those of you coating valve-covers and intakes.... THIS is your home run in the prep-process.
For other metals you might be coating in the brass/copper family, A02 is the way to go. In my humble opinion, brass and copper (especially) are the hardest substrates to powder coat and this would best help your adhesion during the whole process. Order this product and you'll no doubt have a good chance at longevity for your coating.
Stainless has always been a bear to coat as well. SSB370 is the way to go if you need it. Who knows... you may have a reason to finally powder coat that DeLorean that's sitting in your garage after all!
Tip for those who coat Stainless Steel and copper/brass while on the subject. When these metals heat, they oxidize very quickly. If anybody's ever tried to buff that off, you'd know what a pain in the you-know-what that could be. Make a simple solution of Hydrochloric Acid (found at your local hardware store) and water and "dip" the part for approx 30 seconds. Right before your eyes, the oxidation will sluff off and leave you with your original finish yet once again. It's even a good idea to do this on your cookwear once in a while to keep those old pots and pans looking "fresh" for years to come
. Please remember to wear the appropriate eye/hand protection while doing this. HcL is VERY acidic and will burn most anything it comes in contact with almost immediately. Hope that helps somebody out there if they had an adhesion problem......Russ
