Originally Posted by stevepelle91
I'm no expert but Sodium Hydroxide is what you use to strip anno off aluminum, even a small amount would ruin your entire run and you would have to start over again.
Sodium Hydroxide won't cause any problems...unless of course you add way to much. I've been using Sodium hydroxide for 3 years now and I'm still using the same black dye solution.
