Old 08-12-2008, 09:11 PM
tbreaden tbreaden is offline
tbreaden is on a distinguished road
Default Re: Pitstop epoxy not taking flash copper plate
I have used pit stop with some sucess. Try while plating turn up amps to about triple it should be for 30 seconds. Do this when the part first goes in and do it several times . Look at part see if helps , Now I sandblast, Blow off clean air. Flash copper, Then use a copper conductive paint to fill pits( it may take several coats sanding in between) The paint I use you must acid copper. I plate thick. Then light sand (400 grit) Buff light with white compound. Todd
