Old 08-13-2008, 06:25 PM
JTW37's Avatar
JTW37 JTW37 is offline
Caswell Platinum Member
Default Re: Carwiz, got a minute?
Okay guys got the thing cooking, but I think to much so. The PID set to auto tune with outy set to 1. It got up over 525 and the inside glass cracked. The PID showed less then 400. So what did I not do right. Started to set parameters with the PASS set to 0089. But caused the heat problems I think. So shut it off, then went to the auto tune and it was running at 200 and 400, but the oven temp was upwards of 250 and 525. I let it cycle for quite awhile, but this thing worries me as I would most likely burn the powder off. Any idea's?
Thanks.
