Old 08-19-2008, 05:23 PM
Harleydad's Avatar
Harleydad Harleydad is offline
Harleydad will become famous soon enoughHarleydad will become famous soon enough
Default Re: question about pc'ing chrome plated parts (I searched)...
Originally Posted by x1rider View Post
I couldn't find conclusive answers. I'm looking into PC'ing brand new Harley chromed pieces (no chipping, clean parts). I saw that some people recommended just sandblasting, cleaning, and pc'ing and others said to remove the chrome layer with muriatic acid. I'm a little confused now. If the parts are in good condition, can I just sandblast and PC the parts?
Thanks a lot in advance for any help.
I like to put chrome thru an out gas cycle (450 degrees for an hour) to be sure the chrome holds up and doesn't bubble/blister, if it does it would need to be stripped.
If you're applying a solid color you can lightly blast (or scotchbrite) to etch the chrome a bit, blow off with clean dry air and if you choose spray down with the cleaner of your choice (acetone, denatured alcohol, etc.....nothing petroleum based). Be sure it's completely dry before you coat.
If you're applying a trans/candy color, clean really well with hot soapy water to remove any polishing compounds and dry well with clean dry air. If you wish to wipe it down with acetone or whatever you can. I usually follow that up with a tac rag or lightly pass a hand held propane or mapp gas torch over the part to remove any rag lint or dust bunnies.
