Old 09-06-2008, 03:35 AM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: Blasting cabinet recommendation
No recommendations on a particular cabinet but after using different kinds for years, the better cabinets use a foot feed air valve. They all clog, some more than others depending on media and humidity. I don't know if you can find a good one for $300. If your cabinet size works for you now,an alternative would be to invest in a higher grade gun for the unit.Most of the good cabinets are $800 up and come with a dust vacuum. Good luck on your search.
SS
